- Accessing old floppy disks (Gen:1)
The Icon Bar: News and features: What is your current RISC OS setup? (Justin Fletcher)
Posted by Mark Stephens on 06:45, 16/9/2020 |
Networking is all WiFi.
  markee174 (08:16 16/9/2020)
  arawnsley (09:58 17/9/2020)
    nytrex (11:37 17/9/2020)
      nytrex (16:59 20/9/2020)
        gerph (20:20 23/9/2020)
Mark Stephens Message #124943, posted by markee174 at 08:16, 16/9/2020
Does all the
work around here
Andrew Rawnsley Message #124944, posted by arawnsley at 09:58, 17/9/2020, in reply to message #124943
Alan Robertson Message #124945, posted by nytrex at 11:37, 17/9/2020, in reply to message #124944
Alan Robertson Message #124948, posted by nytrex at 16:59, 20/9/2020, in reply to message #124945
Charles Justin Ferguson Message #124950, posted by gerph at 20:20, 23/9/2020, in reply to message #124948
